Hi, I would like to make coins, small, like 2cm with a hole inside to sew on textiles.
The attached picture is an idea, what it looks like. It can be used for bracelets but also sewn on shirts.
Can someone produce this?
It is not hard to produce. The mould is the key to produce it. If you are planing to produce custom make design, you should invest time to get a injection machine.
