Howto for the Myriad - Injection Machine (Work in progress)
References
Part/Assembly “300_TriMounts”
Note: be aware that the pipes come in different diameters!
The handwheel drive needs to be locked in place by using 2 thrust bearings. The lower side needs to be locked with a shaft collar to prevent the rod from moving upwards.
The thrust bearing can be substituted by using a ball bearing and a washer ![]()
