btmetz
(btmetz)
February 23, 2022, 12:02am
after seeing someone elses idea for a mold quick release and the v4 idea, I though I would share mine.
running the extrusion at 60rpm, HDPE and 250c temp setting, I was filling a mold circle of 65mm x8mm in 30 seconds.
With mold changes, and running 4 molds, I was able to average 50 shots per hour.
The vice grip pliers are welded to the plate.
The mold is 3 parts, water jet cut. top bottom middle. Plaved in the mold aligned, clamp. and extrude. need welding gloves for this.
@btmetz
Leaving one side of the mold fixed to the extruder is a great idea, and the other part of the mold could be attached to a hidraulic piston to automate the opening/closing of the mold
Have you tested this design already?
I like this idea! I might do this on my injection machine! Thanks!
btmetz
(btmetz)
February 23, 2022, 8:49am
5
those units in the youtube videos are a big step backwards from the existing machine development.
btmetz
(btmetz)
6
there was a South African guy using a car jack to open and close a mold for a kickstarter that was stillborn…
btmetz
(btmetz)
7
hydraulic is too expensive, although i am looking at a hand cranked unit and a timer to run the machine and control the amount injected.
This unit below is 106USD.
It runs a small 12v pump. Replace the pump with a SSR (solid state relay) and you got a effective way of metering the amount dispensed.
