Lunch box
Similar to the Fruit Bowl project Kristel Breukers and I worked on the Precious Plastics project for the TU Delft.
We used the same (Material Driven Design method to work with the plastics.
But we had a different goal and used a different machine to accomplish that goal.
Our goal was to create a lunch box using the injection machine. The idea is that people bring their own used plastics to someone with the machine and the lunch box mould who can then make a personalized lunch box for them.
The cool thing is that every lunch box will have unique characteristics (material and colours). The thought is that the owner of the lunch box could proudly show others how precious used plastics can be and trigger others to create a lunch box of their own.
In the following video, the idea and vision are explained (password: preciousplastics):
video
We managed to get to a point that we could actually create a small scaled box made out of PP, but with some more time and effort, we believe that an actual lunch box can be created. The biggest pitfall is in creating a mould, which takes a lot of time and requires skills and proper tools.
In the following video, a summary of the production process is shown (password: preciousplastics):
video
Sorry… I posted in the wrong thread and can’t find the “delete” button.
Lots of people here are talking about how, in industry, the normal way to make a mould is to CNC a block of aluminium but how CNC machines aren’t that commonplace especially in the third world.
I’d strongly recommend a visit to http://www.homofaciens.de/
Norbert Heinz has an ongoing project aiming to provide education in machine building using everyday materials and simple tools. His CNC Machine V3 has a lot of potential and could me the answer to mould making problems.
I have no experience in injection or extrusion but do have experience in commercial vacuum forming. Look into heating a plastic sheet in the top of oven then when sagging, take out and place over mold and turn on vacuum. There are several videos on internet that show how to build and use a vacuum mold. Should be able to create a full size lunchbox suitable for our fat American kids. Good Luck.
Nice idea @Paul, it could be a very helpful tool to spread the project. Cheers!
I’m promoting an idea about to create a Mould Design Community (or a mould repository) to faster start-ups here http://onearmy.world/community/forums/topic/mould-design-community-what-if/ Your experience and knowledge are very welcome!
of course, I naively assumed that the “new” plastic would melt right away when entering the mold… would it be possible to do a “to stroke” injection? or does the already injected plastic become solid to fast?
i believe this almost has to be for the injection machine (it has a shaft that is used to insert the plastic, not needed when you use the compression machine.
I believe that the size problem would not occur, or at least would not be so prevailent when you use the compression machine, because one can create a much higher pressure… but that should also mean that simply increasing the length of the lever on the injection machine (and thus the leverage) would make it possible to use bigger molds…
@davehakkens
, any ideas on this?
This mold is for injection machine, I think so.
Regards,
Sebastian
Brilliant…
Had similiar issues 🙂
What machine did you use?
Injection or compression?
