Hi All,
As i couldnt get the 27mm hex bar we had to go with the 25.4mm instead, we also want the 2.1 upgraded version for laser cuts.
Im sorry if this is already posted but i couldnt find the packaged files anywhere when i used the search function for the 2.1 upgrade and the smaller knife holes so i will upload here with an easy to search topic name, im sure someone else can use them moving forward
Here is the laser cut files with new dimensions using 2.1 files
