I need some help of experienced shredder builder around the world
My potential steel supplier told me he can only get the steel bar in 28mm diameter.
I understand that this change requires the hole in the shredding knifes to be adjusted to 28mm diameter, too.
Are there any other impacts?
Any other parts that need to be changed?
Will this change cause any problems e.g. due to not enough space in the box or something?
Any advice is appreciated.
Thank you for your help.
