what if the knife materials are made of mild steel?
I don’t know that buy I know that suspension of trucks has super hardened steel. Maybe you can use that instead from a scrapyard
True but most of them are curved which is not how the knives should be. When you try to heat them to roll them to straightness then you will lose that hardness property which is factory graded.
