Shredder Gear Box Thingy
Hi Guys,
The gear that you’ve used on the shredder motor (the 90 degree thing between motor and shredder shaft) – what is it exactly? Does it have a specific ratio or speed reduction?
Do you think id run into problems with torque if i mounted my motor shaft directly to the shredder shaft? I’m confident that l’ll be able to achieve the speed i need, but im just not sure if im gonna go into some kind of over current straight away at normal load. Have you guys tried this?
Cheers,
Paul
Ahh, thanks for moving it.
Do any of you guys know the worst case torque in N.m would be? I presume with say two bottle lids at the same time?
