Yeah, it should be a standard on Youtube that at the end of each video the author places both hands into the camera shot.
Of course, a safety tie and engaging safety squints should cover it.
On the other hand, I think there is a trade space in blade diameter and speed between the typical paper shredder and the PP shredder, especially if one is willing to pre-process some of the plastic.
‘saw blades of death approach, the spacers between the blades probably want to be almost full diameter’ – yeah, indeed – it gives me just nightmares thinking about doing & completing this machine even with the best tools around.
Folks, sometimes it’s best to ignore this sort of wishywashy stuff on Youtube – if they don’t popup with follow up videos or better versions – save your time & money
Eventually you could knock out a a few portions of the discs but then the risk of fractures and a nice face decoration is getting just higher …
I’ve been thinking about the saw blades of death approach. Since it will be taking very small bites, the spacers between the blades probably want to be almost full diameter to support the blade. I like the threaded compression mount you show.
