Rotational Molding Manufacturing Processs
Share all your information, queries, suggestion related to rotomolding manufacturing process and we invite suggestions to make it more eco-friendly and optimize way.
Thanks
did you used any cooling system to cool the mold?
Hello @aiehareniego,
have you managed to solve the stickiness problem?
Thanks,
Jegor
We’ve been trying different types of coating but nothing works. Thank you for your suggestion. We’ll try that one. Sure, I’ll post again some pictures of our work.
@davehakkens We’re using PET bottles. I see, so that’s why. Here’s the pictures of the result of our last experiment. We only used a small amount of plastics for this experiment (150 grams to be exact).
Do you have any suggestions on what type of coating can we use for it?
Hi, my friends and I are working on this project but we are having a problem regarding the mold. Our machine is working perfectly fine, but the result is a failure because the plastic is sticking on the surface of it. Did you use any special type of coating on the mold so that it will not stick on it? We use stainless steel in making it.
