Realistic Costs – Shredder
I started out building the shredder enthusiastically. At the time I did realize the cost of 180 euros wasn’t realistic, which didn’t bother then, thinking it would come to a bit more or maybe double. I’ve got the actual shredder done, the frame costed, worm gear costed, motor bought, and now the total is probably going in the direction of 750 euros. I think mostly because some of it just has to be bought new. Is anyone experiencing the same issue?
Realistically, would someone (from near here of course) still be interested in buying these things when those are the material costs alone? I’m not so convinced anymore that this is still all viable.
Please help restore my faith someone!
Well, conversely, my shredder is half finished and so far I’ve spent less than 100 euros on it, most of that being raw materials (steel). However I’ve done all the machining of the parts myself and it takes a long time! Probably 50+ hours and counting, and my design is different (about half the size). I’ve yet to source a motor, which will probably be the most expensive part. I do think some of the pricing in the bill of materials is ‘optimistic’!
I think it can be built cheaply if you are prepared to spend time on it, or are lucky enough to be able to source parts cheaply/ for free. But by the time mine is finished I’m sure I wouldn’t part with it for 750 euros.
@fabirihotmail-com
Sound’s good ! Say me when you have finished.
@geat I think I could sell the whole Shredder between 1200 and 1500 Euros depending of motor power and with all new parts. next month we will see.
Around 1700 euro in Switzerland. With second hand stuff whitout the lazercut.
@calderson Hi Chris, I’ve finished my shredder although it never feel entirely finished…
Do not go with timber. I actually found a steel table frame on the side of the road. It was a tad larger than needed and i ended up using a 18mm ply top. Bad idea as this has too much flex meaning the motor and shredder unit move too much. I have an Oldham coupler which corrects mis-alignment, but even with that in place i’d still have to add steel to the frame and bolt the units down properly.
Are you in Auckland?
Hey @brasem Jusy wondering how you got on with your build? I’ve just found this treasure trove of magic and am really keen to get building. I haven’t welded for years but have access to the tools at work. I think I’d be keen to go with the metal plan. How did the wood work out for you?
I just assembled mine after having the blades and spacers plasma cut, by a shop in New England (I’m in Western NC). It was tedious to refine the beveled edges inherent in a plasma cut, but, I was able to assemble the shredder at a great cost.
DOUBLE set of blades and spacers – $100
Square shaft, turned to 3/4″ at ends. $20
Junkyard motor – $10.
steel for frame – $30.
bearings – $30
electrical – $70, includes paddle switch and breaker on the motor, plug and new outlet, later, found a junkyard drum switch.
gearbox – $300
couplings to motor – $40
—–$600
the gearbox was a bit overkill. I bought a new 3.5hp unit one to match my 3HP motor. After buying this gearbox, I’ve probably found 4 smaller 2hp units at our local junkyard.
We set ours up as a ‘multi-machine’ w/spider couplings on the shaft. Easily removed to drive other devices, like our parts tumbler and roller mill. Designing in this kind of modularity helps us justify the expense.
Not to sound too proud here… but knowing our way around the junkyard and learning to run a wire welder have really been a big help with the budget.
Raymond…I just quoted crazy amount for parts only for the shredder parts no boxing or anything. If your parts are good I want to order from your place. I’m just starting getting things together but have a bit of scrap for the framing and some really good support for welding. Let me know how it goes.
In Austria the costs forthe lasercutted parts are 900Eur.
The cheapest price with help of a friend where 550 Eur.
without motor, frameing, hex shaft and electronic….
Hi Guys, I’m in Auckland, NZ and just ordered my laser cut parts for 110 NZD, got 1 meter of hex bar for 43 NZD (still needs to be machined), found a suitable motor on TradeMe (populair online secondhand market place) for 100 NZD.
I’ll have to order some electronics/bearings of ebay which i reckon will amount to 50 nzd.
I’ll build a timber frame, since all houses here are timber build, heaps of demolition materials around. Timber will be free or for a few dollars.
Hopper made out of roofing iron or old flashings. Free or a few dollars. Rivet them together instead of welding.
Realistic estimate at this point: around 350,- NZD (225 EUR / 335 AUD / 252 USD)
I’ll have to see if the laser cut parts are done well. If so, anyone interested in having them shipped from New Zealand?
Cheers
Raymond
I dig it!
I honestly think the double shaft is the way forward.
Hi. Where did you get such prices?
Thnx in advance.
ALx
@novaqui The crowbars I have had for a long time, I don’t think it would be cost effective to go out & buy a new one, someone also mentioned because they hardened steel you might encounter problems when getting someone to machine it.
Sorry I can’t be of more help, I’ve put my build on hold at the moment 🙂
@enviro could you please guide me and put the link of which crowbar you used.
And guys, maybe I am wrong but I have quote here in Australia of 200 AUD for laser cutting all the parts for the shredder.
You guys are getting ripped off.
Hi Guys,
Just thought I would add my input.
I have tried to get quotes to have the shredder box laser cut or water cut here in Australia……best quote $900 AUD
And a motor, best I could get new was a 2KW with 70 rpm, and 1:40 gear reduction ratio – $900 AUD also. Thats as is, with the shredder direct from the precious plastics plans.
Well I decided to check abroad, and see what I could get it done on the other side of the globe.
I was able to get the shredder box cut, in 304 grade stainless, and the hopper, and the frame!! all shipped to Australia (FOB of course, no idea if there would be any further costs to get it from the post to my house) – for….drum roll……$180 USD……not bad I reckon.
If I wanted 100 shredder boxes, the whole price comes down to $102 USD per unit (all 3 parts, just have to source a geared motor……
Have a great day.
@aust & @andyn
Hey Guys, I like the idea of your design. Where did you get it from? I’d like to price making it, where did you get the cad files etc.? Or did you make it yourself?
Cheers,
Paul
@paulfreed
I just looked around the internet and liked the twin shaft design better. The only parts I drew were the cutters, the rest I made as I went along, with a little trial and error. I’m putting together a video of how I built it, but I’m still working on the finishing touches to the machine itself.
@aust
Very interested in your designs. I too am in Australia and was wondering where you are located.
I’m not technically minded and have never done any production or building work other than a little DIY woodworking at home, would like to talk to someone who has working experience with steel etc.
would love to see your machine in action
Mines a little different. I have 4 sets of blades for mine. 4,6,8,10 & 20mm. That’s 1/8, 1/4, 5/16, 3/8 & 3/4. Cost for mine was a hair under $800aud. I’ll write the price list below. Mines a modification of Thymark – Filamaker as its a stronger design in my opinion. Most of this has lots of excess due to minimum order sizes and using what I had first before buying anything.
Parts list:
2 x 17x335mm Extra long CRV Hex Key $78
5 x 6202 15x35x11 Bearing $20
2 x Drive Sprocket 50T 9.525 Pitch 06B
Chain (20mm bore required welding and machining to 10mm bore) $110
2 x Drive Sprocket 10t 9.525 Pitch 06B Chain (10mm bore) $8
1 x 3HP 2.2kw 1730RPM 4P Hyundai Motor $140
1 x 3m 06B Chain $26
100 x M4x20mm Hex Machine screw Black $13
2 x 20T Spur Gear 35mm 10mm Bore $41
1 x 4mm Hex Tungsten Tapered Tap $5
20 x M5x20mm Black Set Screw $9
20 x M4x20 Black Set Screw $-
1 x 35x30mm Annular Cutter $88
1 x 25x30mm Annular Cutter $55
1 x Pin 6mm for 30mm Annular Cutter $22
All steel was 4340 which was made from offcuts from my work. Electronics where free. Another few hundred for parts and labour. I’m very fortunate as this would have been hundreds of dollars.
It cost 2hrs labour @$60hr Machining and water jet. Water jet doesn’t ruin the factory heat treatment of 4340.
Mine assembles in just a few minutes including it’s 25:1 compound chain gearbox.
L
