Projects - Open Source
Introduction
We´re investigating and collecting data, projects for all sorts of protection gear. Please post new links and sources here. We will curate the posts and bring them in order.
How to help :
  1. Signup and reply here
  2. you can use the editor to add links and pictures
  3. To write lists or more advanced content, please use the Markdown Syntax. For instance, to write a named link :
[My link](some url)
You can also use HTML! To make things easy, please write it with extra information as the category:
### Masks
[My link](some url)
Masks
PlasticHub : We started developing a mask, to be injected or extruded from TPU. Status : project preparation, in collaboration with PlasticOceans.org. Links being added later here.
Ventilator
Research and design
Parts & components
Media
3d Printable PPAP Respirator with Filter
3D Printable Mask
3D Printable Mask with replaceable filter element
3D Printable mask
3d printable mask with large square filter
3d printable mask
3d printable mask
Emergency Powered Air-Purifying Respirator (PAPR)
12v Car air purifier with HEPA filter + heat moisture exchange filter + plastic bag + tube + 12V lithium battery pack
Hackaday Article
Originally tweeted by Naomi Wu
DIY PAPR Hack
3d Printable Mask with Round 3M pP100 Filter
Mask for Round 3M P100
Closed Visor
3d Printable closed top faceshield visor headband
Closed visor headband
3d Printable Mask with full filter assembly
Mask with filter assembly
Mask
PAPR “Space helmet”
PAPR Space helmer
Space Helmet
Ventilator image
Aerosol Box
Aerosol Box
Vacuum Formed Mask
Vacuum form
OpenMask PAPR hood and respirator
OpenMask
OpenMask
Idea for Contactless UV-C Sterilizing Delivery Service
UV-C light is said to kill the virus on exposure. The virus can be spread on surfaces, meaning that groceries and supplies deliveries can be part of the chain of infection. These deliveries are most urgently required by vulnerable people in isolation and sick people in quarantine.
Idea: UV-C Sterilizing Car Top Box
A car top box could potentially be adapted to house UV-C lights, the interior surfaces coated with reflective material such as aluminium foil, and an actuator fitted so that the top box can be opened from inside the vehicle. A small loudspeaker could also be mounted with a microphone for communication.
The driver can then collect groceries etc which are loaded into the top box. Without getting out of the vehicle, the driver can then close the top box and turn on the UV-C light. This should sterilize the contents of the top box while the vehicle is traveling. On arrival, the driver can open the box for unloading, again without leaving the vehicle and risking exposure.
I will work on this idea and edit this post accordingly.
Top Box
Prusa Visor headband
Visor headband
Prusa visor headband
Prusa’s updated version with closed top
Protective Suit
Sewing Pattern
Faceshield/Visor made with Precious Plastic Extruder
How to
Extruder Faceshield
Open source face shield validated by American hospital now produced by Ford https://www.delve.com/assets/documents/OPEN-SOURCE-FACE-SHIELD-DRAWING-v1.PDF
The story in Wire
