hi, any suggestion for motor, builds, or any parts for Australian people ?
hi, so far i found this motors, reducers . see pictures below… could somebody tell me if its ok for the shredding
What your looking for in a motor is torque to run the cutters, was looking around at work and on looking up realised that the motor on the roller door would be ideal, it already has a reduction gearbox designed for heavy loads, on timing it it ran about 12 to 15 rpm, to change the rpm for a bit more speed would only require a change of cogs, it’s chain drive, you can get one from Bunnings, it’s virtually plug and play, cheers from the mexican.
Where are you?
I’m in Brisbane
