Massive props to everyone around the whole world who has helped get precious plastic to where it is now… really cool stuff
While browsing the files in the new machine-kit I saw that the machine building tools are only available in 4mm… For those who do not have access to 4mm MDF, like me, here are the individual .dxf’s you can use to cut the jigs from your 3mm material
All files can found here:
-=Machine Building aids (3mm)
I also noticed that there are no plans for marking the barrel to be cut… so I drew those up too (they’re for 3mm, so you may need to tweak yourself).
‘njoy ~
