Laser cutter can't read DXF files
We want to lasercut the (metal sheet) parts for the shredder. But the online tool from the cutter (SOPHIA) sees too many mistakes in the DXF files.
What to do? Does anybody have tips?
Hey @fade-roymarkinez,
my lasercut company also had issues to work with the files, so I converted them again until it worked.
I put them in this Google Drive Folder.
Can you check
  1. if you can download them and
  2. if they work with your company as well?
If it works, we can replace the files in the download package πŸ™‚
I had my shredder cut about a year ago and had no issues, it probably depends on which software do they use to import the dxf files πŸ™‚
@katharinaelleke!!! You are the best!
Thanks for sharing the files, no more mistakes to be found.
Let’s replace the original files, hahaha!
