hi to every one,
after completing compression machine to make compression mould for different components and what process actually takes place inside the the oven during operations
hi to every one,
Hi there,
I guess you’re actually asking how to make a compression mould?
Could you please make your question/s in a clearer way so that we can help you out better?
Thanks in advance!
Hello @nagaraju
I recommend you to check out this post:
http://onearmy.world/community/forums/topic/free-moulds-making-class/
and this one:
http://onearmy.world/community/forums/topic/mould-design-community-what-if/
@nagaraju the mould is filled with plastic and placed in the oven. the oven is then switched on. the plastic starts melting and then it is subject to pressure with the help of the typre jack. this pressure helps the molten plastic to take shape of the mouls. after appropriate time the moulss is taken out and cooled down, then it retains its new shape
