where to get?
i found PID on Ebay and Banggood… but I can’t found the heating elements?
where to get?
@swets any wattage should work fine, the only thing you need to watch out for is the voltage. Depending on where you live, you might either get a 110v or 220v heating band.
The one I got is 300w, but you can either get a 150w or 400w version (I don’t recommend anything more than 300w though). The only difference is that if you get a lower wattage band, it will take a little longer to heat up (few seconds)
https://www.amazon.com/gp/product/B00N41CX70/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
Thanks!!!
how many watts is good/normal?
hi @swets ,
try “band heater”
