If you’re running this in the UK it will be operating on 50HZ so the figures on the left are the ones you need. Should be enough for the standard extrusion, 0.75kW = 1 HP, more is recommended if you’re using a compression screw to make beams etc.
@tafnstuff, I didn’t realize. We were hoping to do a lot of our recycling with PVC pipes already collected, as they are in good condition and need little cleaning. Maybe we can upcycle them? As we collect plastic from the beach we have an endless supply of non PVC plastic (unfortunately) to keep us busy.
@joandarcy, Be carefull with PVC, in Precious Plastic we don’t recommand to work with it because of the fumes. Burning but also melting PVC can creat chrloridric acid and a few more really bad chimicals .
Thanks for the advise, we actually do want to make beams so I guess we will have to look for another motor. I see you are based in the UK, can you recommend a supplier?
We will have 3 phase electricity in our work shop. We have bought a small second hand industrial shredder, as we are dealing mostly with fishing waste from the sea and one of our main sources of plastic is PVC pipes from fish farms.
