Powerful dual-axis shredder, cabable of shredding up to 15mm thick plastic into 2mm granulate.
v4 modifications
- More robust housing
- Smaller blades which yield in better performance
- Stationary knifes have been adjusted to avoid clogging and jamming
- Made it work for using a sieve since v4 design destroyed it self
- Professional wiring and auto-reverse
- Optional : Auto-Plunger
Variants
- 2kW : This version has a slightly smaller chamber than the v4 design
- 4kW : This version has the same chamber size as the v4 design
- Auto-Plunger. This addon enables safe shreddering by using an electronically driven plunger
Features & Details
- Jam detection with auto reverse using industrial components
- Motor overheat protection
- Status lights
- Emergency button
- Modular and professional firmware
- After sales service
- Enclosure and hopper from stainless
- 2 different sieves included
- The upper hopper with door can be flipped back
- Hopper system can be detached fast for cleaning
- The bin has a window
- Easier maintenance
- Auto-Stop after idleness
- Modular and safe hopper
Brief
- Status: Mature - Rev-A
- Version: 1.3
- Last Change : Sunday, July 30, 2023 8:28 PM by lovebird -
dh shredder v2.1 | lucy-clamp-30mm | discourse meta
Specification
| Motor | 2.2 - 4kW | 1480 RPM | 220V or 380V |
| Gearbox | Bevel 1:60 | ||
| Motor protection | thermal and magnetic | ||
| Rotor diameter | 11cm | ||
| Hopper inlet size (Chamber) | 25cm x 25cm | ||
| Electricity | single or 3 phase | ||
| Status | Tested and Mature | ||
| Version | V1.3 (Revision A) | ||
| License | CERN OHL v2 | ||
| Certifications | CE | ||
| Extras | Auto-Reverse | LED Feedback | Auto-Stop |
Source : http://files.osr-plastic.org/files/osr-machines/shredder/obelix/specs.xlsx
