drilling machine as a motor?
Hi. I was thinking, since the motor is expensive in some places, could I use a drilling machine
plus a speed reducer instead of the motor?
For example, using a drilling machine with 300W and 2800 RPM with a speed reducer of 1:350
would produce a rotation of 7.8 RPM (almost 10 times slower than the 70 RPM), but a torque of
348N.m (stronger than 270N.m).
Would this work?
@julianocesarlechetasantos
I don’t think a drill will work, you need something with much more torque. However, you are free to try and test. You might have luck shredding soft-thin plastic, but thick plastic pieces will make your drill sweat for sure.
I missed that part. Coupling a drill with a gear box sounds interesting. I saw a few gear boxes on ebay for around $50 that look like might work with a generic drill
http://www.ebay.com/itm/Boston-gearbox-speed-reducer-/262599606050?hash=item3d2427ff22:g:gGgAAOSwtnpXnKy9
Sure,but AS I SAID: drilling machine PLUS a speed reducerID
This would INCREASE the torque. Resulting in a higher torque than the original project.
