here’s what we did end up with to address some of the safety issues with the v3 shredder design. i stole the most from others on instagram
frame : 40x40x3mm tubes, is scale-able and forgiving, important are the shredder mounts, being at least 10mm thick
shredder enclosure: can be done with a DIY metal bender (see colin furze) and with more requests, it’s around 30 Euro when sending this to a vendor, stainless
control – box: stainless, you can detach it, enough space for upgrades, side plates need to be removable but water proof ! (or better said, beer prove)
**times,
**frame : 4 hours
shredder enclosure, 2 – 4 hours
control enclosure, 2 – 4 hours
outcome
– can’t fall sideways
– doesn’t need floor mount (should have 10 mm threads at the leg to plug stand-offs/level or wheel plugs)
– can be still carried by 2 person up the stairs, total weight 42 KG, make sure people can put sticks into the frame to carry it away
– fits on the back seat of a car
– enclosure and motor can be removed/added in 10 minutes
– frame provides precise holes to align motor with no further fiddling
– any drawer can be used
– pleasant height of 1.10m , for people higher than 1.50m, if hand in shredder, easy to get out, … i hope
extra costs : 40 Euro
design and CAD soon in library!
