Emilio Díaz Milier and Alan Saenz Burrola, under the guidance of teachers and designers Moisés Hernandez and Ashby Solano, part of the team CENTRO’s 6th semester Industrial Design students are building the injection molding machine.
This project is possible thanks to the collaboration between MTV, Dutch designer Dave Hakkens and CENTRO.
The machines will be exhibited at the opening of Disruptive Fest in the Entrepreneur Week in Mexico City to be held from 03 to October 8, 2016.
¡They are working really hard to reach the goal!
CENTRO de Diseño, Cine y Televisión
Av. Constituyentes 455, Ciudad de México
2798 9000 @centro_U
Welcome to Precious Plastic @centro
I’m glad to see more Mexican folks joining the project
You might want to check out the Precious Plastic Mexico site, they are currently experimenting with plaster molds and have seen great results
hola que tal, actualmente estoy construyendo la inyectora pero consegui un tubo de 26 mm interno y una barra de acero (la que va por dentro) de 25mm. con 1 mm de difencia tendre algun problema? creen que el plastico se filtre?
