Getting the shredder blades fabricated by a local shop is expensive. So iv been working on a cheaper alternative to create blades out of a suitably hard material (bronze or brass).
So far the project outline looks as follows:
Create prototype pieces>Create vacuum former>Create foundry>Metal casting
Materials needed are:
+ 4 or 5 pieces of plywood
+drill
+ vacuum cleaner (household kind)
+ thermal plastic sheet
+ Wax
+ casting plaster OR green sand
+ a plot of land (Dont have a foundry in an apartment please)
+ (depending on foundry type materials may vary)
Steps:
1.) Create prototype blades and hex bar out of cheaper material
(I used a wood cnc machine for this but, if you are precise enough, it can be done by just using a to-scale printout of the blue prints and carving the pieces out of some soft, medium to high melting point, material with a knife)
(Note: step 2 & 3 can be skipped if you choose sand casting over lost wax casting)
2.) Create Your own vacuum former
This may sound intimidating but its essentially just a plywood box with holes drilled in it. Instructions on how to make this are here:
– Youtube: XRobots – How to build a vacuum forming machine including my easy heating solution
– Hackaday: DIY Vacuum Former On The Cheap
– Georgerockets: Vacuum Forming
http://georgesrockets.com/GRP/Articles/vacuform.htm
3.) Create wax molds
The vacuum formed molds we just made can now be filled with wax to create wax molds. After that, you can use a casting plaster or sand casting to create a suitable mold for liquid metal
4.) Create a Foundry
Again, this sounds more intimidating then it actually is. When it comes to design they can be as simple or as complicated as you’d like. I went with a Dakota Fire Pit, which is made typically made for aluminum, but iv been experimenting with using coke ash and fire bricks to increase the temperatures.
WikiHow: How to build a metal melting furnace for casting
https://www.wikihow.com/Build-a-Metal-Melting-Furnace-for-Casting
Mother earth news: Build your own home foundry
Youtube: How to make a metal melting foundry. MELT ALUMINUM, BRASS, GOLD, SILVER. Capable of 1800 degrees!
5.) Casting (Lost wax or sand)
Now that we have our wax molds, our casting plaster (or green sand), and our foundry, we are all ready to go!
Sand casting:
Youtube: How To: Aluminum Sand Casting at Home, From beginning to end on Budget Part 1
Youtube: DIY GREEN SAND FOR CASTING – CHEAP, SIMPLE and FAST – MSFN
Lost wax casting:
Youtube: Bronze Casting: The Lost Wax Process
Inscrutables: Lost Wax casting
https://www.instructables.com/id/Lost-Wax-Casting/
Thats it! I know it sounds a little complicated and people who do not have land are not going to be able to make a foundry, but if the community got together then there could be a mail based exchange system in place. Someone who made their thermal former could make multiple light-weight plastic molds and mail them out and someone who made a foundry could cast multiple pieces to distribute. Hope this is some sort of useful!
